Code 172 ego not switching to lean '95 f150 4.9L
Hi all, I recently had a cel on only stayed on for about 15 mins . Then went off. I read it a few days later(after it went off) and it said ego not switching to lean bank 1 . Is this an O2 sensor? I will add I've had a hesitiation /stumble sometimes stall after truck sits 8-10hrs after initial drive . (When leaving work) it doesn't do it as much anymore but sometimes still does. It's been ongoing for about a year. I've replaced within the last yr. TPS,air filter,p/s pump(not related to this issue),belt tensioner, belt,cleaned the IAC numerous times, oil and filter, fuel filter, plug wires . If anyone has any ideas please let me know. Thanks.
MY-302-F250-sux
02-28-2006 11:51 PM
jrs_big_ford_f150
08-04-2003 11:15 PM
