computer reset
computer reset
I have a 99 ford ranger 2.5l, had a code p1401, so replaced the dpfe valve and while doing so found a broken wire on connector to it. So replaced the pigtail for it. Now I have no codes but when I went to emissions after repair it said it was not ready. I drove it around doing errands one day then drove it down the freeway approximately 20 miles each way. Went to emissions and still said not ready. Does anyone know what I have to do to get it through emissions. Thanks in advance for any advice.
I dont know if yours is one of them, but on some Fords the Keep alive memory & horn are wired to the same fuse. See if your horn works.
If the KAM isnt powered the settings are wiped clean everytime the key is turned off.
When i had this problem with my 97 Explorer i replaced the blown horn/KAM fuse & drove it a couple days, then passed Cal. emissions no problem.
I think you need to complete the 'drive cycle', which includes stops, shutdowns, idle periods, acceleration to freeway speeds, slow downs, etc etc etc.
Most techs have figured out a 'route' near their workplace that will exercise all the required sequences. Some will give hints or directions to fulfill the requirements.
Just drive some more, take some short shopping trips, and a bit of freeway, and add in some 'town' driving at lower speeds, with 'stop signs' interspersed. It is kind of a pain.
tom
tom
Have a read through this thread https://www.ford-trucks.com/forums/1...l#post15810549 & down in post 8 I have a link to the lengthily Ford emissions reset drive cycle routine. Let us know how it goes.
bgilfrich
07-11-2016 02:09 PM
MikeyDD
03-10-2016 10:07 PM
