1984 won't stay running
Old 05-03-2016, 12:27 PM
Nathan Cox's Avatar
Nathan Cox
Nathan Cox is offline
Hey guys working on a 1984 Ford f250. 7.3. Changed injection pump and fuel filter. And also o-ring kit. Ran fine on off all day Sunday. Tried starting last light cranked a whole would fire and run eventually. Have it more pedal but would choke out. Or idle and choke out.
Old 05-03-2016, 02:30 PM
sjwelds's Avatar
sjwelds
sjwelds is offline
Sounds like you're losing prime somewhere or running out of fuel. How much fuel in the tank?
Old 05-03-2016, 02:31 PM
Nathan Cox's Avatar
Nathan Cox
1/2 tank......
Old 05-03-2016, 02:59 PM
sjwelds's Avatar
sjwelds
sjwelds is offline
The fuel pick-ups in the tanks are known to break off and not draw it all out.
May be the case, or not.
Best way would be to strap a fuel container to the front bumper, temporarily run a line to the lift pump, and see if that fixes the issue. If it does, you have issues from the lift pump back. If it still has problems, your issues are post-lift-pump.
Where did you get the replacement injection pump?
katman104
03-21-2018 07:40 AM
Sulley8055
06-02-2016 05:27 PM
Crazy2
01-24-2012 09:18 PM
beersy50
11-28-2008 12:11 AM
70Post455
01-04-2008 02:49 PM
Quick Reply: 1984 won't stay running
