91 f250 351 can't get out of its own way
#47
Turned out to be a weak pump, got board redone by a family friend, turned out nice. But it wasn't the problem. Because of the lack of fuel pressure. So on a hunch, I decided to try some gas in my front fuel tank(tank hasn't been used in 10 years) didn't know it even worked, threw some gas in figuring I'd just drill the tank if the pump didn't work or drop it even. Flipped the switch heard the pump prime, and the truck fired right up. Running beautifully, the tps was also an issue, but have a good one now so that code is fine as well. Only issue in having is a code 26 for the TOT. The tranny is shot anyway and I do plan to do a 5 speed swap, so I'll still be taking the truck off the road and fixing any other problems it has. But I wanna definitely thank you Guys for all the help I've gotten, and all the ideas.
Is the code 26 gonna affect my performance?
BillyT1221
19
04-07-2016 11:59 AM
87thhunter
17
03-06-2016 01:15 PM
1982fordf100
10-05-2005 10:05 PM
