***HELP!!!**
***HELP!!!**
I've been working on a 2006 and have had the o-ring underneath the STC fitting blow out 3 times already. Have replaced the HPOP, the stand pipes, dummy tubes, the top O-rings on the injectors and the oil rail O-rings. Everything checks out when get the vehicle hot, and restart. No prblems. But when test drove got bout half a mile and it stalls out and wont restart. Tear it down and air check and its leaking under the STC fitting again. Am I having pressure come from somewhere to cause it? Im installing it correctly I believe and torqueing it correctly. PLEASE HELP!!!!!!!!!!!!!!!!
I was thinking maybe so. Whats my best bet? Loosing nut and installing in truck and tightening after screwing down the small 8mm nuts knowing its flush?
Also Im leaning towards potential branch tubes bent but don't know how to test it. When installing the pump bolts went in smooth. The STC ones screwed in a few times then had to ratchet down the rest each time. they were never pulled, but couldn't hand spin all way down. is that indication of bent branch tubes?
Thanks!
If you have a STC alignment tool see that its aligned properly? Was the original complaint a no hot start? If so did it have the old style STC fitting on the original pump?
My guess is that if that is true perhaps it blew apart and damaged the branch tube, but they normally damage the back cover. Use a mirror and check to see if the branch tube is bent, if its not sealing like you said it should be pretty obvious...or install it and see if the branch tube and STC fitting are flush. If its blowing the O-ring out it will be obvious that its not sealing. If that's the case Id say you've defiantly got a bent branch tube.
Sarge
Sarge
Sarge
Sarge
Had it towed back and pulled it down to find fitting leaking with air check. replaced the HPOP pump and it came with new fitting on it. installed and got vehicle hot in shop and it restarted. went to test drive it around block and stalled out. Brought back and just tore down this morning to find it leaking at fitting with air check.
looking at it right now everything looks kosher with a mirror and my eyes. is there a certain place to look? or a test I can do? I don't know if its so small of a bend of the branch tubes or not. I would hate to sell a branch tube job to the customer if its something like back pressure from somewhere causing this.
thanks so much!
Is the O-ring physically gone, or is it pushed out, or torn? Can you try and snap a picture of the pump the way its sitting on the branch tube. You should be able o run the bolts down by hand in theory if everything is lined up strait. Do the threads look good? I'm wondering if it was cross threaded and when under pressure its pulling the STC fitting up just enough to spit the O-ring out or cause the leak?
Just thinking out loud. Ive never heard of a bent branch tube, its possible I suppose but not common. Id check that rear cover for sure though.
Sarge
catzndogz22
03-02-2017 02:54 PM
