300 6 w/ GM HEI?
But, yes, there are a few choices for a HEI type distributor. The best - and most expensive - is the DUI version:
Ford Distributors Archives - Performance Distributors Performance Distributors
Great company and quality; about $400 or so. Note, they also make a Duraspark distributor.
Pertronix also sells a HEI distributor; I'm a bit confused on all their options, so go through the catalog to see what works best for you, and shop prices. I've seen billet for more than the DUI price, but have seen another version for less.
HEI Distributors
There are also cheap Chinese versions marketed under a couple of names for prices starting at less than $100, but who knows how well they work for how long. No link; you'll need to sort through Amazon to find one, but I've seen them there before. Buyer beware IMO on these!
The best, proven setup is to go with the stock Duraspark II. Get the wiring out of a junkyard truck, and maybe the distributor, too, but those can be bought as a re-man fairly cheap. I don't have the p/n handy, but the Ford Motorsport blue boxes are still available on ebay for ~$40, so that, plus a JY harness ($20 or less) and a used or reman distributor (~$60 or less) and you have a great setup for the price of the cheapie Chinese HEI.
Like I said at the top, go to the inline forum and I'm sure you'll get plenty of input on what works and what doesn't, but IMO and many others, it's hard to beat the Duraspark setup.
I have a 56 f100 that I am planning to put a 300 six into. I originally bought a complete 96 F150 w/a 300 and 5speed to put in it but I got overwhelmed with the wiring, computer, in tank pump, etc. Then I found a carburated 300 which I thought I would be all set but that is a 1985 with the electronic carb and distributor. I am still looking for a duraspark wiring harness and dist and carb but I saw these HEI's on ebay and was curious. Sure would be easy to just hook 12v up to the distributor...
You might want to put this on the inline six forum for more response.
HEI Distributors
HEI Distributors
I remember the Michigan situation well; I grew up near Jackson and moved to warmer climates when I could. The main thing you want in the junkyard is the harness, but they do make them. Painless wire and American Autowire both have harnesses:
AA: American Autowire Duraspark Ignition Harnesses - Free Shipping on Orders Over $99 at Summit Racing
Painless: Painless Performance Duraspark II Distributor Wiring Harnesses 30812 - Free Shipping on Orders Over $99 at Summit Racing
By the time you buy the distributor and box, it would be north of 50% of the price of a DUI HEI, so I see the attractiveness of using one of those. Maybe a vendor would discount one; I don't know, but might be worth a search.
Good luck, and post up what you decide.
Maybe I got a good one......$76.00 on e-bay "and comes in three designer cap colors!....too funny". Bought it due to needing a slightly longer shaft during the year
mix-match engine rebuild, and of course, the price. To date, I can honestly say that it has worked without fail.
Well, that is better than a GM engine in a Ford. The HEI setup does clean up the wiring quite a bit, and if it's like many of the 30 yr old trucks we drive, no telling what kind of mess and quality "fixes" over the yrs by POs; it is an easy way to get around all that.
Purity
Doesn't hunting down an original air cleaner count for something?
I do agree, it's sickening to me to see the proverbial GM 350/TH350 combo force fed into any Ford.
Mine is a workhorse, not a concours, points dependent restoration.
As far as PO's go..well..my truck's PO was a piece of work. I wouldn't wish that purchase experience on my worst enemy (well,maybe one or two).
I wouldn't have used it in my '51 Merc 109 hp flathead at the time though..
Yes, a Pertronix is a great way also to upgrade the ignition. Dunno if it will help the OP on his situation, but worth looking at.
