Trailer weight
Originally Posted by PowerLines
If I remember correctly my 13 crew ecoboost has a little over 7,000lb tow rating. What would you guys consider to be an ideal weight for a travel trailer? Running the stock p rated michelins and 3.55 gears. Thanks in advance!
Of course the truck has to work, it's pulling around more than double it's empty weight! You should see how a loaded vs. empty semi truck handles, it would probably blow your mind just how hard that 450-HP engine has to work to even get up to speed. They do it every day though, for hundreds of thousands of miles...so the fact that it has to work isn't necessarily a bad thing.
I think you're going about this backwards. What's the ideal configuration of a travel trailer for your family? Find that, determine whether it's within the capabilities of your truck, and go from there.
an ideal weight, for me, would be something within your listed towing limit.
with your configuration and the size of camper you are looking at, you should have zero problems finding something you can pull.
when you get into something 29ft or larger, then weight can become an issue.
If I had your truck, I'd look at the floor plan and features of the camper and not much more (aside from price). I don't think you are going to find a 24ft long camper that weighs more than your truck is rated to pull.
Absolutely, this is a big factor. However, i think most camping trailers are about the same frontal area.
But this is the reason that very heavy boats tend to feel easier to pull compared to similar weight trailers.
Wolverine69
Missouri Chapter
08-06-2007 05:57 PM
Ibby
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-03-2006 09:41 PM
bigblue1971
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
13
08-30-2001 03:28 PM
