Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-14-2003, 02:16 PM
wildchild wildchild is offline
Garage is empty, add now
wildchild is starting off with a positive reputation.
Cool supercharger swap
CALLING ALL GEAR HEADS
I have recently come across a take off supercharger. Off a 2001 ford lightning w/5.4. the car was rear ended and the owner has given me the supercharger. My question out there in cyber space is what parts will I need. I have only the supercharger and the intake. I want to install this supercharger on a 2003 ford expedition with a 5.4 in it also. some of the people around here say that i will need to get a new computer and wireing harness along with all of the misc. parts to go with it. does anybody have any help for me on this, what parts i will need and where to get them. or someone here in M.A. that I can bring it to. I am starting to get desprite and would be greatfull for any help
  #2 (permalink)
Old 08-18-2003, 08:59 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
supercharger swap
Fuel injectors, intake, computer, wiring harness.....
__________________
The best is yet to come....
  #3 (permalink)
Old 08-21-2003, 05:12 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
supercharger swap
Depending on how you want to set it up. If you are wanting to set it up exactly like the Lightning, then a new computer would be needed. If not, you could chip yours with a program for the supercharger and any other mods. If all you have is the supercharger and intake, there are a few other pieces you need. See if you can get all the parts you can off the Lightning.
I do not have a Lightning, but know the supercharger install. Check the front of your engine and the front of the Lightning engine for brackets. You will probably need another idler pulley and different belt. Also, on the supercharger and intake - does it have the intake elbow to be able to connect your throttle body to? Does the intake have blowout valve (I don't know if the Lightning uses it or not) ?
Your 5.4 came with 19lb injectors, right?!?!? You might want to go to 24lb to be safe, depending on the boost pressure. Anything over about 6 lbs would need at least 24lb injectors. When you do, you have to recaliibrate your mass air to match the injectors.
I haven't looked at either engine close enough to remember it all - just trying to give you some extra info on what this might entail.
I wish someone would have given me my supercharger...
Let me know what you find out...
__________________
David
FTE Super Moderator
Join us in the Utah Chapter!!!
When you can't buy what you want, build what you want.
  #4 (permalink)
Old 08-22-2003, 08:01 AM
supercharger swap
well thanks for all of your help and advise. I have finally have gotten some awnsers from the ford dealer. the says that i can leave te injectors alone if i am going to build this supercharger mild, such as in the case of the harley truck and not to go as extreeme as the lightining. He has also sent me a complete parts list to help guide me thru this. If anyone else has anymore input on this please submit your post.
Thanks for all the help
Eric
  #5 (permalink)
Old 08-22-2003, 09:40 AM
CobraXP's Avatar
supercharger swap
He must be considering mild as 6 lbs. The 19 lb injectors, along with your fuel rails and fuel pump will support that, but above you would want to change them. Its good he gave you a copy of a parts list. Did he say whether they will sell you individual pieces from the kit, or do they sell the install kit together?
__________________
David
FTE Super Moderator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
