Best ELC coolant
I can only find the Rotella ELC concentrate that meets CAT-EC1 requirements. I can't find it in a 50/50 mix online or in my local store.
It would be easy to buy a 1 gallon concentrate bottle along with a gallon of distilled water and make a 50/50 mix.
edit: My bad. I can't find Shell ELC on walmart.com
Rotella "ultra" isn't EC-1 rated and is for sure not the best coolant for your 6.0. Rotella ELC is EC-1 rated and contains no silicates. I'm not sure how it stacks up against other brands but that's what I'm running in my own truck now. My local Tractor Supply store keeps it on the shelf for a decent price.
I haven't read any recommendation from International for a brand name of coolant or even a type of coolant (CAT EC1 vs ELC) but I have read International's factory fill on the trucks with the VT365 engines was silicate free coolant.
ELC means Extended Life Coolant. It's extended life because it can safely stay in service much longer than the old green coolant we used to use. The older coolants are silicate based, meaning the primary effective component of the mix was a silicate. many ELC contain small amounts of silicate.
EC-1 is Catapillar's own specification number describing a coolant that among other things, does not contain silicates. Other manufactures are allowed to refer to this (CAT) spec on their packaging and literature. EC-1 coolant is referred to as an ELC because it also has a longer service life.
To put it another way, All EC-1 coolants are ELCs, but not all ELCs are EC-1 rated.
I couldn't find the EC-1 rating on this bottle, but it was "rated" for 15+ cooling systems and good for 600K miles. It also had a red cap on the bottle. I'll do a little more checking on it. 50/50 is fine for topping off when I change thermostats, I was just concerned about the compatability. It's the first time Wally world has carried this, at least at this store. Actually the first time I've seen it, period.
If it's the Rotella "ULTRA" it isn't EC-1 rated but to be honest I don't think it matters much especially just for topping off. I got a bit frustrated on the labeling of the Rotella stuff in the store and had to spend some time on my phone before getting the right answer. I don't know why but they seem to be making the labels confusing on purpose.
I've been using the Rotella ELC (non-untra) product. Initially I got it from our regional Shell distributor but now I get it from my local Tractor Supply as Rusty does. I'm now using it in all my diesels, truck, tractors, Chipper, .... this summer will convert over my GMC 2-stroke powered A-C Dozer. It's a good product.
I only get the concentrate. Since you can never remove all of the flushing water out of a block the only way to build up a true 50/50 concentration in the cooling system is to measure the final drop of water out of the cooling system and then from the stated capacity of the motors system calculate the added coolant and water you need to build up.
If push came to shove, I'd use it. I have yet to see any ELC that isn't a HOAT or OAT and without silicates that claims anything close to 600K miles -- the "other" ELCs will be 100K maybe up to 150K. 600K to 1M miles is another league, the league we all want to be in...
