Project Lazarus-The Mare Resurrection
Old 05-29-2016, 06:20 AM
tshrager's Avatar
tshrager
tshrager is offline
Originally Posted by FI460
Arent you still doing close to 30 psi too?
Yes. It will still bury the boost gauge if I try. I really wouldn't push it past that though as I didn't want to toast the turbo.
  #167
Old 05-29-2016, 11:08 AM
FI460's Avatar
FI460
FI460 is offline
Well heck... I don't need to fix my up pipes to fix my boost problem. I'll just get stage 2's!
  #168
Old 05-29-2016, 01:26 PM
fordpride's Avatar
fordpride
fordpride is offline
Looking good Todd
The stock turbo will be over spinning and start to stall around 37psi. and become a paper weight after a couple time of that. I know this cause those 180/80's were mine and I trashed my turbo with them even after bts cut back the stageII tuning.
P.S. I hit 43psi with stock turbo.
  #169
Old 05-29-2016, 01:29 PM
fordpride's Avatar
fordpride
This is them hitting 30psi just pushing the go pedal like you would passing someone
  #170
Old 05-29-2016, 02:24 PM
tshrager's Avatar
tshrager
tshrager is offline
Originally Posted by fordpride
Looking good Todd
Thanks Mike!
Yeah you really didn't need much to sky rocket the stock charger. Here's a vid of when I first got them in. Still had the e4od in it. I think my tuning was a lot less aggressive than yours. I wasn't anywhere near WOT in this either.
  #171
Old 05-29-2016, 04:09 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
As someone who got the chance to drive Todd's truck, I can assure you it was running well!
Looking good, Todd! Got it done yet? Lol. Jk.
  #172
Old 05-29-2016, 05:56 PM
fordpride's Avatar
fordpride
I wasn't saying it wasn't running well. Just pointing out the potential that's left because of the tuning and stock turbo. I always had a issue with being smokey because of the stock turbo that was the reason I keep having the tuning cut back.
  #173
Old 05-29-2016, 06:05 PM
madMatador78
Oh I know you weren't saying that. I wasn't saying it either. Lol. I was comparing to my junk that can't get out of its own way. An unfair compaison Lol.
Yes I agree there was much being left on the table in the configuration it was in. It will be a real beast when it's all said and done.
Keep on it Todd, it's gonna be well worth the effort when your all done!
  #174
Old 05-29-2016, 10:13 PM
martin72's Avatar
martin72
martin72 is offline
Late to the party. Looks good Todd. I like A fat bottom girl.
  #175
Old 05-30-2016, 11:09 PM
mcali2's Avatar
mcali2
mcali2 is offline
Wow. How do you get such fast boost? Mine is slow and lucky to hit 20. More like 15. I even added a custom wheel from rifraff.
  #176
Old 05-31-2016, 05:49 AM
tshrager's Avatar
tshrager
tshrager is offline
The old girl would get down the road alright!
Thanks Kevin!
There are quite a few factors in this, but the main one is much bigger injectors than stock. It's a viscous cycle with mods, reliability and budget.
  #177
Old 05-31-2016, 08:18 AM
fordman67's Avatar
fordman67
fordman67 is offline
Thanks Kevin!
Mods,improvements,maint sure are enough to keep a fella broke as a joke.
  #178
Old 05-31-2016, 10:26 AM
nossliw's Avatar
nossliw
nossliw is offline
Motor, trans and t case are out of red and red is out of the shop. We were able to pull the ZF and motor as one. It was really tight. I don't know if you'd be able to pull them together with just an engine hoist. We used the skid steer and with a little persuasion it came out.
Glad it did! I knew I wasn't hi off my rocker. Looking back i know we did a few with hoist, the majority were done with a gantry over the truck for that exact reason. Glad you got her out!
  #179
Old 05-31-2016, 11:46 AM
tshrager's Avatar
tshrager
tshrager is offline
Boy was I glad as well. Not that it would have been hard to drop the trans as I had everything else out of the way. However, that day turned into a much longer day than I thought and I didn't want more work than needed. Ended up going to buy 1/2" extensions at Oreillys just in case. 36", 24" and 28" for 25 bucks is hard to beat.
  #180
Old 05-31-2016, 11:51 AM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Watching those vids are going to make me spend money that I don't have!
My buddy pulled his engine with the E4OD and transfer case attached. Not sure why.
Quick Reply: Project Lazarus-The Mare Resurrection
