starting issue
Old 04-30-2016, 12:48 PM
bilchris's Avatar
bilchris
bilchris is offline
starting issue
2000 EX with 7.3 diesel 234000 miles. After several attempts to start the battery is to low and I get code 1670. I can jump it with a charger and it starts. Checked the battery cables and pulled the starter and had it checked at Advance. All checked ok. Don't know where to go from here. I think the 1670 code points to the IDM.
thanks for any help
Old 04-30-2016, 12:54 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
In this case, the P1670 probably points to the battery voltage dropping too low for the IDM to stay on line while cranking. Have you had the batteries load tested? Checked all terminals and ground connections?
Old 04-30-2016, 07:31 PM
Otto396's Avatar
Otto396
Otto396 is offline
Sounds like a bad connection somewhere to me if the batteries and starter are ok.
Check for corrosion and broken cables/wires.
jed1894
23
11-28-2016 08:18 AM
jchilcot
10-20-2016 06:14 PM
El Campo
1999 to 2016 Super Duty
08-03-2015 10:24 PM
Bobtailfan
Electrical Systems/Wiring
06-21-2012 01:48 AM
99F350bigorange
07-09-2011 04:04 PM
Quick Reply: starting issue
