edelbrock preformer rpm cam any good?
Edlebrock says stock or their springs. Summit says you must replace the springs.
FWIW I would replace the springs and upgrade the valve seals while I was at it. This cam is good up to 5500 rpm. You think your old stock springs will hang on for that? Stock these motors probably never saw 5000 rpms.
What engine are you putting this in? What compression ratio? Headers? Performer intake or other fine brand?
Being a long duration cam compared to stock, it isn't going to work to it's potential in a stock low compression 360 or 390.
Go to the "search" function above the forum threads. Select "Advanced Search". Put the word "cam" in, and search the FE forum. You will find a ton of threads, and more than one like this one:
https://www.ford-trucks.com/forums/1...nd-to-use.html
J Hodges
20
06-17-2017 10:40 PM
SIXD9R
09-10-2008 04:25 PM
fordnut2008
08-27-2008 01:39 PM
biggut
01-22-2008 01:29 PM
buckawanga
06-22-2003 02:31 AM
