VIN help
VIN help
I am sure this has been asked a million times but I cannot find a link to decode myself. If someone will post a link I will do the leg work of decoding my plate, well the truck I am looking at. Also while I am here I will ask your opinion. Guy wants a grand for this. Hasn't been started since 96. What do you all think? The only rust through is on the drip rail.
OK, stand by. I do not have the decoder ring. Numberdummy and maybe one other person does. I do not believe there is a reliable site that has all the codes. Some codes mean different things in one year or series than they do in another later series.
That should have an FT engine in it, most commonly the 330. There are two versions, the MD and HD. A 361 would be another possible OEM engine.
Two speed rear axle?
What are your plans for it?
Tires and brakes can be breathtaking.
F60 = F600 2WD
D = 330 2V Heavy Duty FT engine.
V = Kentucky Truck Assembly Plant.
BE2046 = 1978.
194" Wheelbase.
B = Dark Jade Metallic.
F602 = F600 2WD .. 19,200 lbs. GVWR
DR8: DR = Jade Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
54M: 54 = Rockwell/Timken Single Speed Rear Axle / 6.83-1 / 17,500 lbs. Rear Axle Capacity.
M = 7,000 lbs. Capacity Ford Front Axle with Power Steering.
19,200 lbs. Gross Vehicle Weight Rating.
57 = Houston TX Ford District Sales Office, where the original selling dealer ordered the truck from.
BE2046 = 1978.
194" Wheelbase.
eberf
10-28-2016 07:49 PM
81F100C
08-06-2015 04:59 PM
