ignition switch
ignition switch
so I have had my 87 f350 for 5 years. when I bought it, it had a push button start hot wired in the ash tray. I was told that the ignition switch was bad. so recently I ordered an after market switch and put it in. went to start the truck and the ignition would barley turn. I would have to twist the steering wheel back and forth to get the wheel to unlock but it wouldn't even make it to the aux position. so I put the old switch back and it will only turn half way but not enough to start the truck. any ideas?
See parts catalog pic for numbers in bold.
The ignition switch is located at the bottom of the steering column, it's actuated by the 11A599 rod
The 11582 ignition switch cylinder is located in the upper flange. Below it is the 3C610 bearing retainer, 3E700 bearing and 3E717 brass gear.
The gear strips, the rod binds up.
It's not the switch. It's a little cast aluminium pivot piece inside the steering column that transfers thrust from the key down to the rod which activates the switch. You have to disassemble the column from the top to get to it, which is a little bit of a pain - removing the steering wheel requires a puller, and there are 3 tight-clearance allen screws which face down; I think you actually are supposed to drop the column to get to them without scratching up your dashboard down by the column.
Received 3,090 Likes
on
I watched a video on how to change that part. But I guess my main question is why did it only happen after I change the switch? And why depending on which switch can I get into different positions? If I put the new switch and I can't even unlock the steering column. If I put the old switch and I can get the ACC but not to the start position
Also having a real hard time reconnecting the ignition to the actuator. The hook that connects to the pin, I just can't get to connect. And t still seem to have the original problem
on
if you have tilt wheel, the only way to get the actuator in is to remove the tilt mechanism.
and once you have the actuator in, you have to align the rack and gear behind the key cylinder just rite, otherwise you will not get all functions.
what i do is set the last tooth on the gear with the first tooth on the rack. this usually gets the aligned properly.
think I know
so I think what happened. when you put on the new switch it was not in the right position. Take the switch back off, there is a hole that a small rod on your column goes into. put a small screwdriver in there and pull it all the way back. It slides pretty easy, and when I say back I mean if the switch was installed on the column pull it in the direction that would be toward the driver seat. This is the accessory position, push forward one click, you are now in the off position. Reinstall, make sure the rod on the column is inserted into the small hole. You should be ready to start. There is a possibility that the rod is not properly seated now, but since you have to take the switch out anyway you can make sure you have it in the right position before seating the rod. Hope this helped.
jdusten81
04-11-2011 08:08 PM
RabidJade
09-28-2003 01:16 PM
wildjon300ci
04-01-2003 07:06 PM
