65 F100 2wd cab
65 F100 2wd cab
I'm new to the 61-66 trucks as I've focused mostly on the 67-72. I decided to build one of these finally and have been learning and reading a lot about these trucks the past couple of weeks.
My 65 F100 2wd swb has a cab with the steps on the rocker. From my reading it looks like the 65-66 2wd drive trucks should have a smooth flat floor without the steps. Am I correct in thinking this is a swapped cab from a 61-64 or from a 4wd truck?
The VIN tag looks like it decodes right for truck, but I certainly could be wrong on that and number dummy will clear it up instantly.
Its dark out when i took the pictures so the flash made the pictures a bit rougher to see. Transmission code is A, axle code is C2.
All help and input is greatly appreciated.
Tom
Tom
The "step": Here's an easy way to remember which cab the truck has, or should have...
If the truck was built with front leaf springs the cab has the step.
If the truck was built with coils, it has no step.
This simple rule makes it easy to understand the construction of the '65-'66 models, especially the 4wd ones.
Is there an exception?
Eric
Eric
Pic from 1957/63 truck parts catalog: See numbers 16472/16506 for the deep cab step, visible when the doors are opened.
1961/64 all; 1965 F100/250 4WD; 1965/66 F350/1100; 1966 F250 4WD / All these trucks have front leaf springs.
1965/66 F100/250 2WD & 1966 F100 4WD do not have this type of cab step. See pics in posts #3 & #4 for what the abbreviated cab step these trucks have...looks like).
All these trucks have coil spring front suspension.
1959/67 F100: When Limited Slip was ordered, Ford usually installed the Spicer/Dana 44 rear axle, because the 9" with Limited Slip was not available in F100's until 1968.
However, Ford also offered the Dana 60.2 (1963/66 F100); Dana 60.3 (1966/67 F100) rear axles. Both have Limited Slip, were installed in lieu of the Dana 44 if ordered.
denny7170
04-04-2016 09:51 PM
Ruffasacob
03-28-2016 11:18 AM
AlaskanEx
08-01-2010 10:31 PM
