Doing a 4wd crossmember swap into a 2wd 79 f150 with a 302. Appears to have front sump pan. Just occurred to me that the 460's generally require the hump sump or rear sump pans when swapped to 4wd. The 302 pan is a lot smaller. Any input?
Research suggests that all the 70's applications had front sump pans and all 80's applications had the rear or hump sump pans. Of course that doesn't help since the 302 was 2wd only until 1980.
I'm running a rear sump set up in my 4wd with 351w. I have seen a couple F250 4wds with front sumps but there's only about a half inch of clearance between the crossmember and oil pan
