2016 F250 turn signals gripe
frequent user of turn signals, but these things don't do right. I need to be retrained On how to use these new style turn signals. I can hear the indicators in city driving but not at hi way speeds and can see the indicator lights if I drop the steering wheel down low enough, but still doesn't seem like the lever has much of a positive up or down position. The manual indicates a 3 blink and auto return with a slight touch of the shifter. Maybe I just need to adjust to this newer to me turn signal shifter. Can't complain to much when driving a brand new truck.
One other gripe consistent with my other F250s is the dash lights fade out when ever I hook up the trailer lights and the dimmer switch only works for the interior lights and dash lights are almost non existent .
+1 on the checking your trailer wiring for ground issues. I do agree that the turn signals on the new Super Duties do require a bit of a learning curve. When I drove my Brothers 2011 Super Duty I thought his turn signal switch was defective, so when I got my 2016 F-350 I was aware of how they operated, and now that I am used to them I like it.
I personally despise the new euro-sedan style computer controlled turn signals. Even after a year and a half I still can't figure out if I pushed the stalk only to the three(ish) flash point or all the way to the "on" position. About once a week I can't get the signals to turn off when I want them to, so anyone behind me must think that I am drunk or just can't make up my mind which direction I am going.
LOL! I just did that this morning gettin' on the highway...
I'm used to the turn signals and actually like them, and can still screw it up if I'm not paying attention to how hard I push on the stalk.
I cannot stand the same side cancel. If the right signal is blinking and I hit the signal for right again it SHOULD NOT turn OFF!!
I encounter this often when making quick successive turns in parking lots , etc.
It really pisses me off when people do not signal so when my truck turns my signals off I want to friggin scream.
Dash lights are controled with the rocker switch by the light switch. Just don't push it down all the way and the dash lights will get brighter. There is nothing about how that switch works. If you push it to hard than the dome light comes on so don't push it that hard.
As for the turn signals they suck. Why make it so complicated ether on or off not flash 3 times that's as stupid as it gets.
As for manually cancelling the signals, you can push the stalk left or right to cancel regardless of the direction selected. In other words, if you are sitting at a light with the right signal blinking away and decide you don't want it flashing any more - you can push it right to cancel or left to cancel. Either way works.
Now the high beam selector catches me because my Lincoln (and most other vehicle I've owned the past 20 years) requires the stalk to be pushed forward to select high beam. Sometimes when I am trying to click backwards to turn highs down I also turn the signal on. It can be quite the light show then!
My wife's Mazda is the same as my truck. I'm pretty sure it's become the new standard set up for signals, some manufacturers could be lagging a bit but most new vehicles I believe have signals that function the same. I like them myself. No issues.
I wonder sometimes when I read about people having 'issues' with their dash light brightness and stuff if really their lights are just set to 'auto' and the odd time when they turn off or on near dusk or dawn or differing light conditions is the actual culprit. Because my lights, dash lights, and whatnot work flawlessly.
