What Front Sway Bar Bushings do you use?
I recently noticed that the front sway bar bushings (the red ones the po claimed to have replaced just before I bought the Ex about one year ago) seem to be worn past their useful life. I can easily slide the sway bar right and left with just one hand. And there are wear marks on the bar from the rubber wearing down.
So as the title says, what front sway bar bushings have you/are you currently using, on your Ex? How long have they lasted? Do they grip the sway bar tightly so it can't slide right to left? Are they noisy?
Thanks!
Didi
Thanks!
Didi
I drive very rough roads and so far:
Tried moog and they lasted 7 months and were completely shot
Have Energy polyurethane in now and we will see how long they last. Make sure the swaybar links aren't shot either.
I have energy bushings with moog links right now and its very quiet, no rattles or clunks. Time will tell how long they last but I feel your daily road conditions will play a factor.
This. I had the blue Moogs on mine and they went away in a year. Yes, they fit tight, if you use the grease, they wont make noise. Measure your sway bar to get the correct ones. I have the larger F series bar on mine.
Is Moog the only brand that makes blue bushings? Dropped the Ex off at the shop today for inspection and oil change, I had them do the bushings too and they're blue. Didn't get a chance to ask what brand they used. It's noticeably quieter on bumps now but I still have the creak from the drivers front body mount. I think that's my last squek/creak to get rid of.
zavierbr
05-27-2009 06:25 AM
John7894
01-17-2009 09:43 PM
