I've decided its worth fixing keeping
Not as dramatic as the title implies , my 2003 Excursion with 7.3 needs some love and i'm kinda at a crossroad of selling it and getting something newer but fairly quickly realized that anything that I can afford is a clear downgrade. This truck has 190,000 miles but the body is Really clean. To start it needs a new front shock since a bushing failed in a set of Rancho 9000's I added these in 2010 BTW..
What shocks , (I'll change both fronts) do you recommend. ?
I also have a list of to do's
-Replace rubber rad hoses
-Rebuild oil cooler
-Stub shaft U joints both sides
-upgrade water pump flange and Stat (flange has leaked)
-Tranny fluid
-Figure out why on super cold mornings there is sometimes a short delay turning over compared to turning key ( I was thinking maybe Positive cable)
-I have U joints for front drive shaft
Off the top of my head
-Rebuild oil cooler
-Tranny fluid
Story on the truck is this..
Bought it late 2009 from Texas with 110,000 Miles..
I live near Ottawa - Canada..
I installed a DP tuner in 2010..
Just had the Injector cups done.. and changed both harness
Just had a reman #8 injected done.. Injector cost me $1000 installed(ouch)
To insure I am not adding any more 1000$ injectors I was thinking of
buying a stage 1 injector set and tuner from Swamps..
Thoughts on this ?
Kyle
Shocks Billstiens.. You can call Billstiens and they will give you a part number that they recommend for the trucks stance. Then order them from Summit best price I have found so far but someone might know a cheaper spot. I also agree that if the list is that short and easy keep the truck. So far everything else is a down grade. Jury is still out on the new diesel heard some good things but also some bad ones.
Not bad - for the above shop at 5 hrs. per injector it could have taken all week to change all 8 injectors I suppose...
I was thinking bilsteins..
Thoughts on this ?
Kyle
Thoughts on this ?
Kyle
