Dana 80 Trac Loc Rebuild
Is there any way to stack or shim the trac loc clutches to make the trac loc more aggressive on these trucks? I've read tons of info on the D80 about a "restack" but most of it applies to Dodge stuff where they have up to 12 plates/clutches per side. The Fords only have 7 and I can't see any logical way to restack them which would change anything.
Factory Order is:
Side Gear
Preload shim
Clutch
Disk
Clutch
Disk
Clutch
Disk
Disk
I also tried adding an old clutch disk between the last 2 disks but it makes the package way to thick to get the case halves together. Anyone have any input besides the usual "swap out for a locker"?
Factory Order is:
Side Gear
Preload shim
Clutch
Disk
Clutch
Disk
Clutch
Disk
Disk
Rcmgiasson
04-30-2016 12:03 AM
psu1xj
08-25-2004 07:54 PM
Frank T
12-11-2003 06:33 AM
johnsonacres
11-11-2003 06:44 PM
