2003 F-350 problem with lights
So I'm working on my mom's 03 F350 7.3. the lights are acting pretty funny. She has no:
Of course, I drive an old VW beetle that's 40 years old, so my mechanical knowledge isn't necessarily applicable to modern vehicles.
Thanks for any help
- brake lights (no brake light over the bed either)
- rear turn signals
- rear hazards
- headlights
- front turn signals
- front hazards
- front and rear running lights
- reverse lights
Thanks for any help
I assume she has parking and marker lamps on the bed working? If so, begin by checking the Multi-Function Switch.
I checked 34 and 18 visually, and they looked ok, but I'm picking up a pack of fuses tomorrow to switch them just to rule out another possibility.
like PFW said signal comes from Multi Function switch(Turn signal switch in the column). Rear brake, turn, and hazard use the same the wire for all three functions but left and right are different wires, left is LG/OR and right is OG/LB. There is a connector under the brake master cylinder that is a break out leading to the back of the truck.
mkohut
16
06-08-2018 09:36 AM
rterril02
Electrical Systems/Wiring
05-31-2016 06:02 AM
williameub
11-08-2015 06:53 PM
Rentaro
17
07-14-2013 07:51 PM
