Oil leak near drivers side up pipe.
Small oil leak looks like coming down by drivers side up pipe. I don't think it's the turbo o rings. Better not be. But could be I guess.
Anyways. It runs down somewhere by the up pipe down onto transmission. I'm not loosing tremendous oil or anything. Just needing ideas. Will post pics
The oil flow from the leak seems to follow the same path as when I removed my HPx to r&r my turbo. Out of the fitting down the seam of the intake plenum down the back of the head and off the bottom of the bell housing.
The valley is where any Oil leak is going to collect and run out of the drain in the back of the engine. Could be coming from any of the points you have pictures of. Hpop, Oil Lines, ICP, Pedestal, EBPV. Your going to have to degrease the Valley, and then you can get an idea what's leaking
I don't smell diesel. It feels like oil to me when I rub it between my fingers.
I already brake cleaned everything once. , but I need to clean it a little better. I will check the FRX fitting and the HPX fitting also make sure they're tight. I I feel like this leak was present before the installation of the HPX AND FRX though
