Hiccup with AC/Heat
Hiccup with AC/Heat
Morning folks,
My 6.4 has 243k km on her now and up here in Canada this time of year one day the AC is on and next day the heat is on.
I noticed at idle when my heat or AC is on (doesn't matter which) every 20-30 seconds I get a slight hiccup and my rpm's drop ever so slightly then goes back to a normal rpm range. This will repeat when I have the AC or heat on at idle only.
I did my front belt and belt tensioner about 15k km ago.
Thanks in advance.
Thanks in advance.
Ok so here's a little update on my hiccup noise. I've been running the GearboxZ electron tuner for the last 10-15k miles. I ran the original DPF-R before that with no issues. All my weird noises started when I got the electron tuner. I just got my mini maxx today and after my install I drove a while and let it idle a while to see if the noises stuck around. No more weird hiccups or loping. I don't know if that will help your situation but it helped mine.
