Certified and EZ Wire
But something has to go from somewhere to the amp meter to show a charge. I'll have to look at what I have wired already to see if it looks like I'm going in the right direction.
I knew that was a box of spaghetti when I opened it!
I'm not a fan of all the current going through one gauge.
A voltmeter gauge is what I'm going with. A Future project is to get it in to the stock cluster.
If you want to keep your ammeter, it goes between the battery and the fuse box. You'll need a fusible link to protect it. The alternator goes on the opposite end of the loop from the battery.
This is how you hook up a 1-wire so that the ammeter works (loop-type inductive ammeter). It shows the stock circuit breakers but you could substitute a fusebox at the same location, as long as the BAT and alternator output wires connect at that point.
There's very low risk to using an inductive ammeter because no current actually flows thru it. It senses the magnetic field in the wire.
I checked for my schematic and it's gone. Do you have one? There weren't any surprises with mine and the ez wire. The Ez labels are a huge help. Since the colors will not match up, you'll need the schematic. If you don't have a schematic, let me know where you bought the switch and I'll try to dig up the diagram. You could figure it out with an ohm meter, but that will be a last resort.
Will
Will
Well, I think I have the alt. straight. I'll find out once I get it ready to fire up. Now I'm inside. Really not comfortable with this area at all. BUT the schematic Ross posted helps.
*****, did you just cut the Chevy pins off the wires to connect them to the turn signal? That seemed the most likely thing to do. I have to say, I'm not real impressed with EZ wire's instructions. They do leave some important thoughts to assumptions. Not all there customers are going to be experienced wire runners.
Measure three times cut once.
Will
Much to my own disappointment, I have to admit defeat. I have tried all the tricks I know and none have worked. I have read and re-read the instructions, same with the tips here. I have read the schematics on every part I can find. Nothing is working and I am getting more frustrated. I have even walked away for a week, no help.
Those of you who have been able to complete the rewire and those that will I the future, I congratulate you. In this area, at least, you are better than I. Now I am left trying to find some one who does know what they are doing and try to convince them to come to me, as this truck ain't going no where.
Thanks for everyone's help. From now on, I will stick the mechanical stuff and installing bulbs.
#28
When it comes to wiring. If you're not comfortable, don't do it.
I break it down to sections. Lay it all out then take it one wire at a time. The labeled wires are your best friends.
Maybe you can join a local car club. there's likely someone there that can help.
Also,any high school auto classes or junior college tech schools in your area? They might like that project as a cool learning tool.
#29
The schools are good ideas but with the school year ending, I doubt they would have class time. I followed all of EZ's directions, laid it out, cut out the wires I knew I wouldn't need, started at the front, then the rear. It's not a lack of experience, I have completed some simple wiring projects in the past. I just can't get myself straight on the mess under the dash. The combination of original truck schematics, EZ wire, Certified and the Chevy column connections are just too much. I just can't separate them enough to know where I am. Like I told you, *****, I'm probably over thinking it. But, the risk of destroying the truck because of an error on my part, is too great.
#30
Unique story: I get up this morning and head on over to let the girl cut what's left of my hair. They aren't open yet, so another guy, who drove up at the same time as I, decide to wait at the door for the few minutes. He's wearing a Harley T shirt so I strike a conversation about bikes. That moved to cars, after a bit and he shows me a pic of the 23 Model T sedan he has just finished. After that he mentions he is an ASE certified Master Mechanic. OK!!!! So finally I ask if he knows anyone that not only understands wiring but would be willing to come to the car as opposed to me towing it to them. He says, he does that sort thing on the side. We get our ears lowered and I wait to get his number. He asks where I live and I tell him. "Let's go look at it", he says. 5 hours later, my truck is running and all the lights work. I have to go back and do the fancy work, cut to length and run the looms. But everything is correctly wired and it runs. Can it get any more unique than that?
