Undercarriage Rust - help with buying decision (pictures)
Hi there,
I finally found a 2001 F350 7.3 diesel I was looking for - good mileage, well taken care of and records to show it. However, there is quite a bit of undercarriage rust - see attached pics. Will this be a problem for the chassis and drivetrain and should this stop me from buying?
Thanks in advance for your thoughts and feedback!
Pete
Pete
This vehicle looks to have sat idle for long, long periods of time. Brake rotors look untouched in months.
The larger thicker bits aren't a huge concern (to me) but I'd look much more closely at small parts like spring shackles etc. Anything thinner or small will rust away more quickly, if those are easily replaceable not major concern.
I'd be looking at the body underneath and perhaps under the stock floor mats. Rust in those spots can be quite expensive or time consuming to repair/replace----the wisdom of that much work should be considered.
Frame/chassis stuff is easy, body not so much.
HTH
HTH
Not sure what kind of shop you're having it inspected by but if its a chassis shop they'll be able to assess what if anything really needs done.
A body shop would be best for issues related to the underside condition.
From what I see by these few photos I don't see any perforations in the frame, rust shown for the most part being surface rust that forms when a vehicle sits idle for long periods of time.
Received 3,099 Likes
on
UGH !
If the motor goes another 100K and the truck cost $2000 then its a horse race.
That is a huge work time of rust. How are the rear shock mount$ ? the wells before the front wheels ? Rear bumper ? Brake n oil lines ?
always a better buy around the corner.
I have excellent results with thorough wire brushing, thinned linseed then Rusto....maybe for critical areas. But linseed requires a HOT climate for drying to a plastic state before winter sets in.
try a small punch n hammer see if the punch goes thru the frame. The sellers just love this....
whats that chrome sardine can ? a rust limiter ?
ek9beezler
01-10-2016 11:36 AM
