7.3 won't start when hot
I have a 1999 f350 with a 7.3l in it. A week ago I stopped at the pump and topped of my tank and when I went to restart it it it would crank and not fire. I had it towed and replaced the cam sensor with an aftermarket one. It ran but it would cut out when I got into the throttle and wouldn't start when hot. I bought another aftermarket one and it did the same thing. I tested the hpop pressure at the back of each head and everything checked out perfect while running. I replaced the Ipr with no luck. And I also tried unplugging the icp sensor and it didn't make a difference. It starts perfect when cold but when it's hot and you shut if off it will just crank. I replaced the cam sensor once again with a ford one and everything worked perfect and it started no problem for a day then started doing the same thing again. Any ideas? I've taken a close look at all the wiring on the motor and it looks good. Battery's and starter are new. All the cylinder contributions test good as well as the injector buzz test. I'm not noticing any change in oil. Oil was changed 800 miles ago
Ditto on that...Aftermarket sensors should always be motorcraft because they're reliable whereas the others most time fail. Only hot no-start Ive had was the ICP on a torrential downpour of a night and it started while unplugged to get me home. Seeing that you checked the hpop pressure is the oil level up there where it should be?
Here's a quote from HKusp........... "having issues with no ICP when the truck was warm. It was winter and the truck would start when the oil was cold and thick, but as soon as I was at operating temp, if I turned the truck off and went to restart, I didn't have enough ICP to fire the injectors. The external o-rings were failing"
How many miles on the motor? Have injectors ever been changed? Have you been losing any oil lately?
Yes the tach is moving while cranking. My fuel filter looks good it is fairly new and the one I took out last service looked real clean. Oil is fairly new and still seems to be good quality. The oil level in my hpop is close to the top. It's only about a quarter inch down. My Ipr has been replaced with another ford one and nothing changed
