Dorman up pipes
Dorman up pipes
Ordered a set from Rudy's I'll have them this week and I'm gonna tear into the truck on Sat.. I bought the lower spider boots and turbo o rings.. Anything else I should look into before I get the turbo out? Nothing in the valley or around the turbo is leaking... I can't add my signature info until I have a few more posts..
Any advice on things to look for or replace?
Mods include..
Wicked wheel
6.0 IC
Air raid intake
6.0 26 plate trans cooler
55psi fuel spring
Banks big head
Full 4" magna flow exh
TonyWildman tuned TS chip
EGT-trans-boost guage on the piller
Zoodad mod
Foil delete
AIH delete
Mods include..
Wicked wheel
6.0 IC
Air raid intake
55psi fuel spring
Banks big head
Zoodad mod
Foil delete
AIH delete
What are fearless warrior Tug would say...soak them up bolts for a week with penetrating oil
Check the passenger side fuel line at the support bracket under the turbo. Can wear thru and spring a leak.
Plenum reinforcers so you can use t bolt clamps down there and never worry about losing boost there again.
The newer billet turbo wheels are better than the WW, spool faster plus flow more. Riff Raff has a nice one but the current crop from other makers are pretty comparable, from what I hear.
Happy wrenching!
Happy wrenching!
Happy wrenching!
Happy wrenching!
I'll have them today once the brown man shows up.. I'll assemble ad check for sure.. Also thought about trying to clean up the casting inside the babies butt... Couldn't hurt to smooth it out as much as I can..,
If you're planning on removing the turbo and pedestal, you can remove & install the collector and up-pipes together as a set from above, as well as the downpipe. To get the downpipe in & out from below the trans cross member needs to come out.
I did a short write up for my install here. Take your time and it'll be an easy job.
Are you saying wrap first, then paint or visce versa? I wrapped the exhaust on my Harley and it rusted the header in 6 months!! Took it off and ceramic coated them!!! Pricey!! But it was a better setup for sure.. Don't really have the time to have the up pipes ceramic coated, but I could paint em up and wrap them pretty quik!!
You might consider tapping the manifold for a EGT probe. Even if you don't install it, you can plug it and it'll be there when you're ready for it. I've read the write up for doing it with the truck running to blow out any metal shavings, but I like the idea of being able to shop vac out any debris with the up-pipe off. Just a thought, I wish I would have done it.
