Exhaust Manifolds stud or bolt
Studs will be less likely to loosen over time. Factory came with studs. I'd contact ARP fasteners and see what studs and nut they have available for your truck. An old stud would good to have if they want measurements. Or you can spend the extra money on a set of direct fit headers. You won't get much if any power improvement with them and you will see a little more noise due to the thinner tubes but they usually fix the broken stud issues for good. I put headers on mine when mileage was low.
Use stainless studs.
Twenty years ago, the exhaust studs / bolts on the 6.9L IDI Diesel were popping off, especially in school bus applications that had many full load accelerations per mile while picking up students.
International released a stainless steel fastener that eliminated the problem. Tensile strength of the stainless fastener is lower than a Grade 8 fastener, but the stainless material has greater thermal growth. As the manifold expanded, it would expand faster than the stud, and exceed the tensile limit of the grade 8 fastener. The stainless fastener lengthens faster and more with heat, so the tensile limit was never exceeded, even with a lower tensile limit material.
Rumor has it that Ford has stainless studs in the latest service package for the Modular engines (twenty some years later).
Isn't engineering fun???
Bolt or stud makes no difference, although a stud / nut assembly is sometimes easier to install on a V shaped engine.
sprinter87
Modular V10 (6.8l)
06-03-2008 08:47 AM
