underhood light pic needed
Old 04-24-2016, 02:54 PM
tbruz's Avatar
tbruz
tbruz is offline
Greetings,
I picked up a NOS under hood light for my 75 F250.
Could someone post a pic or two or three of how the light is actually threaded through the holes in the under hood support structure and of where its mounted and where it connects(I believe it connects to the solenoid on the P-side fender)
Thanks in advance.
Tbruz
Old 04-24-2016, 07:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Originally Posted by tbruz
Greetings,
Thanks in advance.
Tbruz
You're correct, the wire connects to the battery side terminal on the starter solenoid.
Here's the illustration for the installation from the parts catalog.
File Type: pdf
Old 04-24-2016, 11:08 PM
shanes66charger's Avatar
shanes66charger
shanes66charger is offline
Is this the same on a 78 Mike?? I thought the green/yellow wire right near the connector for the blower motor was for a hood light?
That's a correct 78 NOS harness.....judging by the wire color at that grey female connector i thought it was in with the courtesy/door jamb wiring....switched off by a mercury switch in the lsmp fixture?
Old 04-25-2016, 10:18 AM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
I dont have a pic available, but mine has small wire guides screwed into the hood supports that plug into the 2 prong adapter in the pic of the last post
Old 04-25-2016, 10:49 AM
shanes66charger
Hmmm....i guess if the lamp runs off a mercury switch it wouldn't matter.....but the courtesy circuit is always HOT so either way if that connector on my pic is infact on the courtesy circuit (green/yellow) i coud plug in a light there.......idk wtf else it would be for?? Unless for a/c. But i think thise connectors are inboard just above where harness comes through firewall. .....
Mike will no doubt chime back in lol
Old 04-25-2016, 11:54 AM
benbuilder's Avatar
benbuilder
benbuilder is online now
SUBSCRIBED
Old 04-25-2016, 12:01 PM
shanes66charger
Originally Posted by benbuilder
SUBSCRIBED
May as get educated with the rest of of lol
Old 04-25-2016, 03:31 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The original underhood light that I have definitely wires into the battery side of the starter solenoid. It has an inline fuse for circuit protection and has a mercury switch to turn it on and off, that one is part number D3TZ-15702-A.
That one was used 73-75 after that it shows D6TZ-15702-A from 76-78 (s/n BE0,001) and 78-79 after BE0,001 used D8TZ-15702-A so I would say there was a good chance the wiring changed along the way.
EDIT: I got smart and checked the master wiring diagram. Page 7 of the'79 (I don't have the '78) shows the underhood light plugs into connection C-1112. The description of the plug in the index (it also shows a drawing of the plug) is gray with a single Green/yellow wire. Location: In engine compartment, near dash, r.h side.
Old 04-25-2016, 03:58 PM
shanes66charger
Good info! Thanks mike!
Old 04-25-2016, 04:10 PM
benbuilder's Avatar
benbuilder
Than for the info, but what is that grey plug used for? I see it empty in most pictures.
Old 04-25-2016, 04:20 PM
shanes66charger
That's what i figured mike my 78 is a late one after BE0....its BL....something. yep...gray plug, single green/yellow wire. So it would be tied into door jamb /courtesy circuit.
Cool info thanks again.....cant find any late NOS lights. But ill probably swoop a late model unit or maybe an led and plumb it in
Old 04-25-2016, 04:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There are a few of the early D3 lights around, none of the D6's but I did find one NOS D8 switch still available, if you want the contact info let me know and I'll PM it to you.
Old 04-25-2016, 04:32 PM
shanes66charger
PM me please
Old 04-25-2016, 05:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
PM me please
....PM sent ....
Old 04-25-2016, 06:35 PM
tbruz's Avatar
tbruz
tbruz is offline
All done, I used the D3TZ-15702-A which is the mercury variety.
Took all of about 15 minutes once I figured out which holes to use; plastic snaps were all in the right place and it ties in to the +side of the solenoid.
Will need to add the plastic grommet that goes around the hole where the wire passes through for long term protection though
Thanks again.
Tbruz
Quick Reply: underhood light pic needed
