1948 Ford F-6 Engine temp and gauge issue
I replaced my temp gauge on the 226 H engine F-6 and the new gauge jumps fast to "Hot" only a minute after its started. The old gauge read about 3/4 of the gauge range.
I see that the thermostat spec says open at 177-182 deg F (fully) on the H. What should the engine temp be for operation?
I purchased a temp reading gun and my engine operates after about 5-10 minutes parked at 177-187ish on the front top side of the block. Towards the bottom of the block it decreases to around 155-160 deg F.
The intake manifold side is around 227-295 deg F (at different areas), but I would expect that.
What range is the gauge suppose to represent? I think this is the gauge and not the temp sensor...
Thanx.
Thanx.
I would double check your ground and your voltage on that gauge.
The engine temperature will vary depending on the load and thermostat settings. Ideally, for thermal efficiency and engine oil life, it would be around 190° to 200°F, but maintaining an average of 180° would be good. Over 210°F oil will begin to coke. Under 140° oil will begin to gum and won't boil out moisture that is held in suspension.
That is also the exhaust manifold side. Remember that you are reading the air-cooled radiated outside temperature, not the inside.
Thanx.
Thanx.
As an aside, if you really wanted to know the calibration of your temperature gauge, you would submerge the sending unit along with a type K thermocouple (connected to your DMM) in a pan of water and bring to a boil. It should be noted that no two gauges will read exactly the same either.
It's questions like that, that was asked by hundreds of Caterpillar customers, that prompted them to produce gauges like this. The actual temperatures will vary from machine to machine by a few degrees, so the gauge readings are relative. If it's green it's good, if it's red it's bad. If you're an operator, that's all you really need to know.
Either the new gauge is bad or it's calibrated differently. Like I said before, you will never get two gauges to be exactly alike (except in certified testing standards gauges, that is). For a rough test, remove the radiator cap and put a thermometer in the top tank and run the engine up to the point where the temperature stabilizes and read the thermometer and compare it to the truck gauge. Next, perform the same task using the new temperature gauge and note the difference. Personally, I think the needle being in the middle is too cold. If the cooling system is properly sized for the BTU output (and clean) of the engine at rated load and HP there shouldn't be a problem at all with 180°F.
Yes, but you need the specific absorption and dissipation coefficient rates of the material (cast iron) you are testing through.
That's "1950's normal". Technology and knowledge have evolved tremendously. Believe me, your engine will run a lot easier and cleaner at 180°, but do what you will.
dustyroad
09-29-2018 07:38 PM
49fordv8f4
01-25-2016 10:05 PM
machinist91
10-01-2013 09:56 PM
thordehr
05-07-2012 04:39 PM
