6.2 dead bank - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
6.2 dead bank
Old 04-23-2016, 02:13 PM
tfarms4430 tfarms4430 is offline
tfarms4430 is starting off with a positive reputation.
6.2 dead bank
Hate to join and ask for help immediately, but most of the guys I know and my experience lies with diesels, but my wife wanted a gas, so here it goes.
2011 F-250 FX4 with the 6.2 obviously 160k
Suddenly started misfiring, like will not even go 35 mph.
genesis says only codes are misfires (5-8), random misfires, that bank's cat system below efficiency (guessing from 4 dead cylinders)
injector cutout makes a diff. on 1-4 and no difference on 5-8
good compression (145-155) on 5-8
new plugs getting spark everywhere
getting fuel (even replaced 2 injectors, fuel sprays while cranking)
seems to be pulling good vaccum that does not drop off like a plugged exhaust
they are missing at all RPM's, will not spin over 3000
cam, rockers, and valvesprings have been inspected, and none appear to be sticking
ECM was sent to my repair guy and tested, he says all is well
wiring harness looks good everywhere, going to try to find a good diagram and pin it out just to be sure
exhaust gets hot, like a late burn maybe
I'm at a loss here, by the way I'm Zach , most of my experience is with heavy diesels (farm equipment, mostly old, we're poor) and older gas engines, and 7.3's
really impressed with the 6.2 pulling (other than gas mileage) until this happened, really do like the truck though, driving my old battle axe 99 with a 7.3 and 300+k gets old, when I have a nice one sitting
Old 04-23-2016, 10:03 PM
brickman brickman is offline
brickman is gaining momentum as a positive member of FTE.
Maybe the coils? I had a 5.4 did something similar when a coil went out
Old 04-23-2016, 11:08 PM
RainDesert's Avatar
RainDesert RainDesert is online now
RainDesert is gaining momentum as a positive member of FTE.RainDesert is gaining momentum as a positive member of FTE.
Could any of this be linked to the notorious wire harness on the e-brake lever?
Old 04-24-2016, 09:38 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Check the wiring on that bank, which is what you are about to do anyway
All the injectors and COPs are given +12V, you could have an intermittent bad connection.
Other than that, I can't think of anything else that you haven't already covered.
Old 04-24-2016, 11:04 AM
what is this magical e-brake harness you speak of?
wiring was my last choice because it seems odd that it would occur all at once, and not be intermittent, and I cannot seem to find a good diagram, (I prefer to ohm wires, as 12v or ground sometimes does not tell the entire story)
But seeing as with work, planting, spraying, and an new clutch in the 1466 the wiring is on the back burner, wiring after a week of 20hr days is beyond me
Old 04-24-2016, 12:44 PM
RainDesert's Avatar
There is some talk about it in this thread:
http://www.ford-trucks.com/forums/13...ont-start.html
It is talked about in other threads too.
I have seen other driveablility problems associated to the pins in the harnesses. My friends 6.7 had one in the dash go bad causing random issues. I'm don't know if this could be linked to your problem but maybe someone else has a better idea. If nothing else, you could look into it a little.
Old 05-12-2016, 04:36 AM
I'm at a loss, checked all wiring, all checks out good
even got a couple new coils, no change
we are wondering if maybe a cat collapsed inside, as the one for that bank has big dent in the front of it, the exhaust manifold for that bank gets hot, but I can rest my hand on the pipe downstream of the cat where as the other bank I cannot even hold my hand close
plus to my highly trained ear on cat "rings" when struck with a ratchet, the one with the dent does not
if I get time in the next few days I am just going to cut the !^#@&#%^ pipe and see if it will run, at least I can weld it up if not, getting tired of throwing money at it.
Old 05-12-2016, 11:12 PM
Jeffrey Robinson Jeffrey Robinson is offline
Jeffrey Robinson is starting off with a positive reputation.
Please keep us informed
Old 05-18-2016, 10:31 AM
yep, that cat was blown up inside
want to go with high flow aftermarkets.... any reccomendations?
aftermarket seems to be cheaper than eliminating them and getting a new programmer
any other ideas?
Old 05-18-2016, 12:33 PM
Squisher's Avatar
Squisher Squisher is offline
Squisher has a good reputation on FTE.Squisher has a good reputation on FTE.
Do you have a tuner already? Any custom tune it'd be easy to turn off the rear o2's or a SCT can do it with the canned tunes too.
I've got no cats and tuned for it so that would be my vote.
You pulled that cat and the bank fired right up? Or have you run it yet?
Old 05-18-2016, 10:26 PM
RainDesert's Avatar
any other ideas?
I'm glad you found the problem to be a simple one, once you figured it out. An SCT tuners from 5star is about $400. I have never had to deal with new cats before as I used to be a diesel guy. Let us know what you do.
Old 05-19-2016, 10:34 AM
talked to the boss, she said get rid of them, less than a year and our roads broke one, nice living where even the county highways are rock
do I just gut the cats or weld in pipe?
programming? I don't really care does not really need more power unless I can keep my wife out of it, what is the easiest option? I am fine with factory codes, just want to shut the rear o2's off
Old 05-19-2016, 05:40 PM
Squisher's Avatar
You weld in pipe.
You'll need a programmer of some sort to turn off the rear o2's. Don't worry about it giving you 'to much power'. Because unfortunately that's not going to happen.
Excursion V10 multiple misfires solved steveschroeder Modular V10 (6.8l) 20 02-24-2017 08:47 AM
2002 4.0 runs rough Mental-issues Ranger & B-Series 20 02-22-2017 11:13 PM
4.6 running bad no codes Panama1 1997 - 2003 F150 8 01-05-2017 10:46 PM
2006 ford f150 misfire/poor accelleration fixed hofec1 2004 - 2008 F150 30 09-01-2016 06:17 AM
Misfire under load? NMSOLRBACON 1999 to 2016 Super Duty 2 03-10-2016 09:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
