Truck suddenly died while driving, no warning.
1995 F150 4x4
302
Posting here about a problem that has me a bit baffled. Yesterday I turned onto a busy street at rush hour and the truck completely died before I could complete the turn. No warning of any kind. A kind person towed me into a Walgreen's parking lot where I was eventually towed home.
Looks like the water pump and/or seal has failed, as there was a lot of coolant running from directly beneath it. Nothing leaking at the firewall area or anywhere else that I can see. It's been leaking for a while. I have been monitoring it...topping it off once a week...so I was not shocked to see what I observed yesterday.
What does have me baffled is why the truck just died suddenly. I'm guessing that coolant may have gotten onto something electrical...(maybe a sensor?)...created a short that made the truck instantly quit running.
After the first hour of my 3-hr wait for the tow, I turned the key and it started. I thought about trying to drive the 2 miles home, but decided to stay put and shut her down.
Any thoughts on what might have happened here? I'm probably going to install a new water pump today or tomorrow.
302
I haven't started it since after it was towed into the parking lot yesterday. Not much left in the battery then. I've got it charging now.
PIP is a possibility. I had some issues with the truck not starting obout a month ago. An intermittent thing. I replaced plug wires, cap, rotor button and ignition coil. None of that changed anything. Fuel pressure fine. But after a week the problem stopped and hasn't returned.
I guess because of all the coolant leakage I saw, I was thinking that the problem yesterday was somehow related to that. Maybe it's just a coincidence. I have never had this truck just go deader-than-a-doornail while driving.
tdbarlow1
06-05-2014 11:22 PM
tko5479
24
02-06-2013 05:13 PM
bryanrb
11-18-2012 11:21 PM
FordMuddin'
09-29-2011 10:26 PM
