You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 1999 f150 4X4 offroad and love it. I am having some shaking in the front. It feels like tires are unbalanced. I checked my tires and even swapped them around. Went for a drive and around 50 or 60 mph it shakes at times off and on. I can feel it in a turn more, and seems to be on the left side. I could see no problems when I pulled the wheels. I did recently change the brake pads in the front and they seem smooth when breaking. I have had a CV problem on other vehicles but this has no sound to it, just shakes. Tires look ok. I have goodyear wrangler rt's. I bought the truck used and has been great any help would be appreciated.
Had a similar problem with my old 92 F-150. Ended up the camber adjustors were worn out. This caused the front end to shake between 65 and 75mph, exactly. At +76mph or below 64mph the front end was as smooth as silk. I has those tires balanced and rebalanced I don't know how many times before I finally figured this one out.
__________________
2003 F-350 Lariat CC/6.0L /TorqShift/FX4/SRW http://dan.prxy.org
Born on date: Jan 20, 2003
Number of reflashes done: 2 (05E15 Jan 8, 2007)
Number of C94 injectors replaced: 0
Number of times the EGR valve has been replaced/cleaned: 0
Had the tires balanced and they went out again in a couple days. Thanks to GOODYEAR Wrangler RT's. Tires should have gone another 30k with the tread on them. I bought some Big Boy tires BF GOODRICH T/A KO, anybody else tried these tires. I hear they are real tough.
Unfortunately, i hate the ford TTB, and it eats the tires up like there's no tomorrow. Need to get alignments pretty often on this truck. Tires weren't too cheap either.
Everyone seems to like the BFG A/T tires. I see them on all types of trucks and SUVs. Most of the nicer trucks at the job site have BFG muds.
__________________
1995 F-150 reg cab long bed DECEASED
I6 300-M5OD-4.10 LS
33x10.5 BFG M/T mild head work, torque cam, 2.5" exhaust, roller rockers, 19lb injectors
It may be the ball joint.thats what the problem with mine is.ive never changed a ball joint and im not sure if i want to i know its a bit@#h to get those thing out and the press a new one back in.
I used to drive a 95 F450 wrecker and it had similar problems it turned out to be the steering stablizer shock being wasted. That truck had a mono beam axle with kingpins so it might not be the same. my 2cents
