8.8 Explorer diferential ?
Received 4,110 Likes
on
on
I used one of these. then the rear u joint that I had with the Ford 9" worked with the Ford 8.8". I had to have the shaft shorten a bit.
Flange Yoke Diagram 4a Spicer 2-2-1379 adapter Ford Explorer pinion flange 4.25 inch diameter 8 bolt to 1310 U joint. 3" x 3" bolt pattern, 4.25 inch diameter, 2" center hole, 1310 series U joint (1-1/6" x 3.219"
Christopher2
04-25-2005 04:47 PM
tchapma1
02-03-2003 08:46 PM
