Sleeper dually build?
Old 05-22-2016, 06:46 PM
Fordman96's Avatar
Fordman96
Fordman96 is offline
Originally Posted by fordpride
Please explain to me how you got a tuner for a dodge to work on a PSD ?
Plugged the CTS tuner into my truck, punched in my vin, was given 3 options for tunes plus guages. Put it on extreme. Have tuner back to friend. Truck now flash tuned.
  #47
Old 05-23-2016, 06:29 AM
fordman67's Avatar
fordman67
fordman67 is offline
Originally Posted by Fordman96
Looking at a 6.0 intercooler with pipes for $300 back home. Just have to buy the e99 spider intake.
Also there is a 08+ 250 here with a shot motor I might see if the guy is interested in selling. It's a king ranch so I'd take the axles and interior and I don't know what else off it.
Why would you do an ic with an e99 spider if you are planning a t4 setup? The t4 will also come with ic pipes to connect the dots...wich brings me to that ic at 300$ is twice what it should be.
  #48
Old 05-23-2016, 09:47 AM
Fordman96's Avatar
Fordman96
I was looking at it because right now I'm looking at supporting mods. $300 didn't seem too steep when i saw that a whole intercooler setup was like $1100, from strictly diesel.
I'm waiting on a few more details on other things with an '08 SD with a damaged motor. If price is right I'll be stealing parts off it.
  #49
Old 05-23-2016, 10:22 PM
fordman67's Avatar
fordman67
Ic kit from strictly for 1100...you are in a different page I guess
  #50
Old 05-23-2016, 10:32 PM
fordman67's Avatar
fordman67
Smh ..edge.. Feeling lucky eh?!?!
  #51
Old 05-24-2016, 09:02 PM
Fordman96's Avatar
Fordman96
I just wanted to see what a tune would do to her, think I'm going to put her back to stock. Although she seems to run better, I don't like how hard it shifts.
As for the IC kit it was sinister diesel, my apologies on that. $1,5xx for the kit.
  #52
Old 06-13-2016, 08:23 PM
Fordman96's Avatar
Fordman96
Has anyone ever seen a dually converted to a SRW except it keeps the flares? Thinking of doing it to the truck since I'm not hauling anything. Not sure why except that it might handle a little better off road.
New goals for the truck:
D60 4x4 (either newer axle swap out era appropriate swap)
Flat bed (keep 5th wheel rails, more tool boxes. It's going to be the "rescue rig")
'Move' bumpers (very cool, I suggest looking into them)
Front winch at least
Halogen headlights ($357)
Custom stacks on the flat bed
Off road lights
E-fuel
Trans cooler upgrade
Intercooler
S4xx turbo
238/100 injectors
T-500 Hpop
Exhaust
Maybe a 4" reverse cowl hood
Anything else I'm missing
  #53
Old 06-13-2016, 09:21 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Someone just posted a picture awhile back of a dually with one hugh wide tire instead of the two tires. It looked pretty cool.
  #54
Old 06-14-2016, 06:40 AM
tshrager's Avatar
tshrager
tshrager is offline
I'm not a fan of the super singles. But that's me.
  #55
Old 06-14-2016, 08:18 AM
oldbird1965
I said cool, what I should have said was different in a interesting way. I'm not a fan either.
  #56
Old 06-14-2016, 08:46 AM
tshrager's Avatar
tshrager
tshrager is offline
Man I don't want to get on santas naughty list! I hear you Glenn.
  #57
Old 06-14-2016, 04:46 PM
Fordman96's Avatar
Fordman96
I remember why I was thinking about it. Because I might buy an '06 SD with a bad motor and take the axles off it
  #58
Old 06-14-2016, 05:13 PM
oldbird1965
You would have to try harder then that to get on my naughty list !
  #59
Old 06-15-2016, 05:22 PM
Fordman96's Avatar
Fordman96
Does anyone know if you can run a non dually hub with like a Dodge or Chevy dually adapter which is the same lug pattern?
  #60
Old 07-19-2016, 06:03 AM
Fordman96's Avatar
Fordman96
Not a big update, but dropped some serious change on new hub/rotor assembly and brake pads because I got tired of the squeak.
Quick Reply: Sleeper dually build?
