Sleeper dually build?
on
1 Post
LOL!! I appreciate that, but I am by far a "pro", and I know enough to get myself in trouble! LOL! I compiled that list because it seems to be a tried and true set up that YOU, Darin, Brian, and others are running! So it is your guys knowledge, not mine! I still gotta get my junk squared away! LOL!!
With correct supporting mods, these are capable of around 425 hp.
Premium Build: $1600 Overhaul and upgrade to new Hybrid Plunger & Barrel assemblies, new Nozzles.
The 238/100 is the next stage up suitable for "525 HP" which I guess wouldn't hurt if I want that mid to high end of 400 ponies. I guess stage 3 wouldn't be that bad since it's only an extra $50.
Stage-2.5 200 cc Hybrid with 30% over Nozzles:
I sure love the 250/200s lol where does it stop tho?!?!
Dumb question.
Once you replace your stock injectors with upgraded injectors can you throw all hopes of fuel economy out the window? Or does something like 238/100 mean the max it'll inject is 238cc and the minimum is 100cc so that way if you're not towing you can daily drive it and it'll act like a normal truck?
#30
Dumb question.
It is ALL about tuning and driving style. Another big variable is tire diameter and gear ratio.
The 238 is cc of fuel per 3000injection cycles I believe
100 is 100% over stock nozzle flow.
