Leveling ride height? 78 f150 4wd
Old 04-21-2016, 10:14 AM
shanes66charger's Avatar
shanes66charger
shanes66charger is offline
Hey guys. My 78 f150 sits up in the back. Id guess about 2" dana 44 up front, 9" out back. It has the factory blocks under the leaf springs in the back that I'd prefer to leave in as i like the height in the back.
What are guys using to level these out? A 2" lift kit up front?
Any thoughts, tips, product or kit suggestions welcome
Old 04-21-2016, 12:05 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Jeff's Bronco Graveyard offers 2-inch lift coils to level out your rig.
Old 04-21-2016, 01:41 PM
shanes66charger
Ok thanks...i checked graveyard out. So how about this one also?
2.5in Suspension Lift Kit for 77-79 Ford 4wd F-100 / F-150 Pickup [410.20] | Rough Country Suspension Systems®
Obviously it comes with shocks, but why does it require swapping the tear blocks? It says the C bushings are 4°. In guessing they're essential. Also appears to have a trackbar drop bracket. Woukd it require longer sway bar end kinks and a longer brakeline also?
Old 04-21-2016, 02:13 PM
HIO Silver's Avatar
HIO Silver
Obviously it comes with shocks, but why does it require swapping the rear blocks? It says the C bushings are 4°. In guessing they're essential. Also appears to have a trackbar drop bracket. Woukd it require longer sway bar end kinks and a longer brakeline also?
Dunno why it would have replacement blocks.
Longer brake hoses really required until a 6-inch lift. On a 4-inch, the the rear brake flex hose bracket should be relocated to provide slack.
Dunno about endlinks...my '73/74 doesn't have swaybars.
Old 04-21-2016, 02:21 PM
shanes66charger
Thanks for the info. Perhaps with the factory blocks its not quite level.....but you'd think they would have figured that into the design....
As far as price difference I guess its a factor but i would like some good quality shocks.....
Not in a rush though so just collecting info.
Thanks again
faer
01-18-2021 05:36 PM
AussieCraiginTX
05-29-2018 05:39 PM
Big Grey
12-27-2012 03:24 PM
79pos
01-17-2004 08:20 PM
fordsrus
11-04-2001 09:34 AM
Quick Reply: Leveling ride height? 78 f150 4wd
