X's & Modded B's. Opinions on my plans please
from a practical stand point if the tapered 350blocks is being used without inducing vibration on other Excursions then it should work on yours but then again, measuring is your best bet.
fwiw, I have a 2 1/2" block with 2.5* of taper and my angles are within 2* of parallel and I have a very slight vibration. driveshaft is balanced. point being, every setup is going to be a bit different.
It's best to remove driveshaft to get measurements.
(Block wheels, e-brake etc so it dont roll when DS disconnected)
I will throw another hick up for you to consider. Pinion angle can change based on load applied and load in vehicle. Note the lower traction bars under your oem leaf springs to mitigate large rotations....mine were actually bent a little.
I assumed a 1 to 2 degree upward angle change due to rotational torque applied to rearend while driving.
So my static angle on flange on rear end was 2 degrees less/more ( depending on how u measure)than what the transfer case angle is. To make things right under loads. IE if transfer case flange is 84 degrees, I would be hoping for 85 to 86 degrees on rearend. (Note a 3 degree tapered block woud make the above static measurements 82 to 83 degrees, opposite of what would be needed). Around 80 degrees under load and why people have vibration issues even though a static 83 "looks" good. It may not be.
I don't even want to get into the issue of taller blocks causing more pinion angle change. 1 to 2 degrees seemed to work ok for me.....but I have a cv shaft and needed 4 degrees static. I only put 2 degree shims in.
If your talking about the "slapper leaf" the rubber stops have been missing for the last 100k
Now we have gotten to technical I'm ordering a flat block if it vibrates ill go see the drive shaft people lol
OK, time for me to inject some more confusion (partially based on my often faulty memory). If I recall correctly the earlier pioneers who started swapping the truck spring under EXs went with the tapered blocks to match what the same wheelbase Super Duty trucks used, I think the longer trucks came with the flat blocks. Again this what I think I remember reading quit some time ago....
Intresting.... maybe those trucks had a cv type driveshaft. That would be my only guess as to why the blocks would be tapered.
I think what he is saying is they took the taller blocks out of the same f350's that they took the springs out of because that is what they had or were experimenting with. the f350 has the 2 piece drive shaft with the center carrier bearing discussed earlier.
Left side 3.5" tapered block: Part #F81Z-5598-FA
Right side 3.5" tapered block Part #F81Z-5598-GA
I know you know the technical aspects and the physics involved, Camo, so all I'm commenting on is what has historically worked for Ex owners who have previously done this mod.
Also, I know for a fact that at least three times I can remember, someone used the flat blocks and had to swap in the tapered blocks to eliminate driveline vibration that appeared.
Stewart
I'd be willing to be just as many people put in a tapperd block and had to switch to a flat block. hence why taking a couple of simple measurements is a good way to determine what you need.
fwiw...the first pic I posted is measuring the drive shaft angle, to measure the pinion shaft and output shaft angle this picture more accurately depicts the method.
#28
I've always urged people who were doing this mod to stay with the taper block so as to affect the pinion angle the least, because of what has "always worked" for those that posted on the boards.
I can't remember anyone ever chase a driveline vibration (after doing this mod) by switching from the F250 tapered block to the F250 flat block.
I'm not saying it didn't happen, I'm just saying if it did, I never read about it.
I know the proper way is to measure, so anybody that reads this, do it the correct way to make sure you're golden.
Just a quick side note, the OEM blocks on the 4x4 Excursions are also tapered (you have to look really close), but smaller than the F250 tapered blocks.
Stewart
#29
I can only comment on what I've read here, and over at TDS where I used to hang out back in '04, '05 and part of '06.
Stewart
Stewart
Not sure how much oem 3.67" blocks are tapered but anything over 1 or 2 degrees would cause issues, and I personally would not use them unless flange measurements called for it.
#30
Tom Woods is not only a cool cat but he has done a great job of passing on a lifetime of useful driveline info.
if you really want to geek out on the subject here it is.
Tom Wood's Custom Drive Shafts - Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
the section on angles and slopes has some nifty ways to find your angles
driveline 101 covers the bases of what we are discussing here.
go to his tech page ( link in upper right corner )
