Halp! '66 Steering column suddenly floppy
Old 04-19-2016, 11:00 PM
Elcid's Avatar
Elcid
Elcid is offline
Hi, new to the forum! The steering wheel on my 1966 F-100 suddenly popped off, and now the column is loose. Seems like it slipped out of bushings or collar maybe. Any thoughts?
B
Old 04-20-2016, 05:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
B
The steering wheel is retained to the steering shaft (3524) by a 5/8" -18 nut (350983-S see pic), so it cannot 'pop' off.
Old 04-20-2016, 06:28 PM
resonateur's Avatar
resonateur
resonateur is offline
...check the steering shaft where it attaches to the rag joint/steering box in the engine compartment...
Old 04-20-2016, 07:03 PM
NumberDummy
"Rag joint" (steering coupler) is 3A525 in parts catalog pic shown in post #2.
Old 04-20-2016, 10:42 PM
Elcid's Avatar
Elcid
Elcid is offline
I should have been more specific: The steering wheel retaining nut backed off completely. When I went to reattach the wheel, less of the threaded shaft was protruding, and the shaft had noticeable side-to-side and up-and-down play. The column itself remained firm. The rag joint is visibly newer, but there does seem to be a larger gap between the rag joint
Old 04-20-2016, 10:46 PM
Elcid's Avatar
Elcid
Elcid is offline
...and the lower portion of the steering column (a larger gap where the rag joint fiber goes in)
B
Old 04-20-2016, 11:41 PM
resonateur's Avatar
resonateur
As always, a picture's worth a grand. There should be no play in the steering shaft, except rotational movement.....
kevintoupin
16
06-22-2017 04:30 PM
Justin039
03-16-2017 04:06 AM
FordStolz68
08-27-2016 02:05 AM
IDIDieselJohn
07-14-2009 05:47 PM
ymurf
03-20-2004 09:01 AM
Quick Reply: Halp! '66 Steering column suddenly floppy
