steering issue
steering issue
I have a 97 f250 ext long bed 2wd. The steering feels like there's a delay when going down the road and at a dead stop it take's a 1/4-1/2 turn for the wheels to move. I have noticed the frame flexing quite a bit when I'm turning the wheel waiting on the tires to move is it a weak frame or bad steering components?
You SHOULD NOT be able to see the frame moving at all when you turn the steering wheel.
Figuring out where your sloppy steering is coming from is best done with two people in my opinion. Get one of your buddies to sit in the truck and turn the wheel while you look under the truck at the steering components and see where all the turning is going before the wheels turn.
In your case look first at the frame around the steering box because it might be cracked.
If it were mine and I wasn't sure what was going on with all that movement and steering slop I'd get someone qualified to look at it right away. Hard to tell from your description but it sounds like the steering could go out on you altogether. Not a good thing if it happens at highway speed with other innocent drivers or people nearby. Better to be safe and not take chances until you find out what is going on and get it fixed correctly.
gman97005
06-05-2016 06:04 AM
hotrodbob51
09-12-2010 11:07 PM
86f15035s
12-15-2003 04:47 PM
