ABS recall Help
04-19-2016, 08:59 PM
on
ABS recall Help
I had the 11s24 recall for the abs relay and reservoir cap.
I am now getting the below codes
c1095 for abs pump circuit failure
b1676 for voltage not correct.
Both codes indicate that the new relay is possibly wired wrong or something went wrong during the install.
Anyone else have similar issues.
I have looked everywhere for a wiring diragram on how the abs is suppose to be wired but i am having no luck.
04-19-2016, 09:30 PM
You need to identify what is being discussed.
04-19-2016, 09:36 PM
on
Ok,
I would like to find a wiring diagram for a 2001 ford escape wiring harness for the abs system. or other possible solutions for the codes i am seeing c1095 and b1676
04-20-2016, 02:24 PM
Most likely, they botched the recall.
I've not seen any schematics for the modified circuit, so I have no info on how it's now supposed to work.
04-20-2016, 03:53 PM
on
Does anyone have the original wiring diagram before the recall. The book i bought at the parts store does not show anything about the abs pump
04-20-2016, 08:24 PM
Original is easy, it's in the ETVM. The modification is what's not on hand.
04-26-2016, 02:11 PM
on
Quote:
Originally Posted by
projectSHO89
Where can i get my hands on a copy of the etvm. If i can see the original i can go from there. I pulled the loom off of harness in engine bay. Wires are hacked in several places.
04-26-2016, 02:19 PM
Go to ebay and enter "2001 Ford Escape EVTM" for one.
04-26-2016, 03:55 PM
on
projectSHO89
On way. Thanks for the help
TallTexan
1997-2006 Expedition & Navigator
04-20-2015 07:44 PM
jaybob1807
02-28-2014 03:48 PM
Pablo-UA
Aerostar
10-19-2013 11:48 AM
RA81222
1978 - 1996 Big Bronco
12-02-2007 07:29 PM
my289
02-24-2002 11:32 AM
