I ran 35's (315/75/16) on my 95 F250 that I had. Best I could tell, it had a 4" lift. The lift and tires were already on the truck when I purchased it. The tires were real close to rubbing the front bump, so I spaced the bumper noun about a 1-1/2"
i ran 40 inch rubber on my 88 with a 4 inch lift and had no problems after removing the front bumper for replacement push style bumper without the side extensions.
other trucks had the same thing, but had the bumper sides trimmed for clearance.
just a little trim of the bumper or shim it forward and they should be just fine
but with stock rims the tire will rub the leaf spring no matter what I had 285/75 on mine with stock alcolas for awhile and they would rub occasionally
