83 won't start
83 won't start
Hi everyone. Hope y'all can help. I have a 83 150 with the inline 6. Truck wouldn't start so i replaced the cables. Next morning truck started with no problem. I park the truck and hour later it won't start. Cables check, battery check. Replaced starter selenoid still nothing, replaced ignition module still nothing. Wasn't getting power to starter so I replaced the starter.
New started installed and the truck still won't do anything. The lights come on but nothing else will happen except when I turn the key the rpms jump but won't do anything else.
Bare with me not much of a mechanic. Any input?
Need a little more information.
We know it is a 83 F150 with a 300 but what trany does it have?
Now you say "does not start" but you did things pointing to it not turning over or cranking.
When you turn the key does the motor turn over and not start OR not turn over?
If not turning over what happens any lights or noise?
Than we can point you where to look next.
Dave ----
Dave ----
OK, is it an automatic or standard. If automatic, you may have a bad neutral switch on it. Are you sure the solenoid is wired properly. My main concern is the wire that pushes on to it on the right side when you are looking at it from the pass side. That leads to the ignition key and allows power to pass to the starter.
Ignition switch / alignment issue, or possibly the starter relay is stuck. Try removing the small wire terminal from the relay while it's happening. If the starter continues to run, then the relay is suspect. If the starter disengages, then I'd be looking at the ignition switch and how it's actuated by the key.
FuzzFace2
15
05-21-2016 09:53 PM
Kwill
04-25-2016 07:40 AM
