Rebuilding 87 F-150
Rebuilding 87 F-150
I have an 87 F-150 that my dad bought new. He passed away in 2011 and the wife and I are considering giving it a facelift. It has the 302 in it and I'm not sure how many miles it has on it. I'm sure it's rolled over at least once. I'm thinking fix a few mechanical issues, lift, wheels and tires, and paint and then go from there. I don't know much about the truck. Is there anything I should know going into this rebuild? Anything that definitely needs upgrading to handle some larger tires? Is the 302 too small to make it a decent farm/trail truck? Are there any engines out there that I should keep an eye out for that would be a good swap? I know this year model truck isn't really collectible but it has some sentimental value. I would love any input and suggestions. Thanks.
on
Check for any rust anywhere especially the frame and look for cracks near the steering gear box otherwise these trucks are really bullet proof and easy to rebuild. Anything that definitely needs upgrading to handle some larger tires? GEARS!!! Regearing is really important even with the stock size tires. Depends on how much lift and tire size you go with for what gear to go with. My 88 F150 with no lift and 31s has 4.10s and it moves it a lot better then my dad's old 86 F150 with 31s and 3.55s or his current 90 F150 with 29s and 3.55s. Is the 302 too small to make it a decent farm/trail truck? Yes and no. My 88 302 has a upgraded cam fresh rebuild and better pistons soon some headers and it does ok for DD/trail riding but it isn't the best. If you keep the 302 upgrading the cam, going with GT40 heads, some headers, a good exhaust will help it extremely. I haven't put GT40 heads on mine yet. Are there any engines out there that I should keep an eye out for that would be a good swap? 351W from any year but most idealy 94 (maybe 95)-96 as it has a roller cam that is better then earlier years. The 351 is a direct swap for the 302 minus some say the computer needs changed some don't. I know this year model truck isn't really collectible but it has some sentimental value. I would love any input and suggestions. Thanks.
Trav
on
If/when I have to put another engine in my 88 it will be a 351 roller mostly because I love the power of the 351 and my 83 Bronco has the 351. My family has a 95 351 F250 that once I finish installing the radiator I know will be awesome.
Trav
ech0sh4y
09-08-2015 06:51 PM
78f-150Supercab
49
11-22-2007 06:21 PM
mudball101
01-11-2004 11:49 AM
