1988 f350 coachman rv
It is not a fuel filter on an 89, it is a single tank fuel reservoir with a check valve in it. In 86-87 they did have filter in them but in 1989 they moved the FI filter up by the high pressure pump. As said above you can buy a fuel filter for a older truck like a 1986 Bronco II and throw the filter away and use the "O" ring if it is leaking or needs to be cleaned out.
May or may not have the filter in it depending on the model year.
4Cammer72
11-13-2016 03:53 PM
HKusp
17
02-03-2008 06:39 AM
