2016 F250 Platinum Speaker Upgrade / Sound deadening
Have a 2016 Platinum F250 with the SONY audio and 8" touchscreen. The truck is a huge upgrade from my 2008 F-150 Lariat except in the audio department. I was very happy with the audio in my 150, just find the f250 lacking. One of my first projects was to improve this but I didn't want to modify my truck too much or replace the OEM headunit. I also didn't want to sacrifice any underseat storage or modify the look of the truck in any way. I came across BIGDZL's build and it seemed like exactly what I was looking for. His build is here:
https://www.ford-trucks.com/forums/1...tallation.html
I went with FOCAL door speakers instead of the JL and I didn't use a remote cable to power up the AMP. I instead used the GTO sensing on the LC2i to send a remote signal to the AMP. It works perfectly, the music stays on after powering down the car just like stock. Open the doors and everything shuts down.
I treated the doors and the rear of the cab with dynamat. This is extremely important. Especially with the bass coming out of the Focals and the JL 13.5" sub. The dynamat not only deadens the outside noise, but it prevents vibrations inside the cab and improves the speakers performance. Especially the door speakers. If you don't care about feeling the bass, you can significantly improve the sound of your truck just by treating the doors with dynamat and replacing the OEM speakers.
I'm extremely happy with how everything sounds. I have the EQ all zeroed out on the head unit. The audio is clear and crisp. You can feel the bass and can fine tune how much with the amp adjustment **** mounted at the driver dash. I'm hearing details in the music I haven't heard before especially from high quality music sources. (IE: NOT Sirius radio)
Below are a few pics of the install but if you want more detail and almost a step by step of what I did, check out my install album. 2016 Ford F250 Audio Upgrade (SONY NAV) - Album on Imgur
Dynamat Install on Doors:
Door speaker comparison:
Tweeter comparison:
New tweeter mounted:
Focal PS 165 Installed. 6x8 to 6.5" adapter. Some cutting required. Details in album linked above.
Dash speaker replaced with JL C2-350
Rear cab prep for dynamat install:
Sub Comparison:
Power routing through the grommet on upper left:
Sub level control:
Amp rack and sub box:
Again, there are almost 150 pictures with more step by step in my album located here: 2016 Ford F250 Audio Upgrade (SONY NAV) - Album on Imgur
Shopping list:
Subwoofer:
13TW5V2-2 - JL Audio 13.5" 2-Ohm 600W Shallow Mount Car Subwoofer
JL Audio SGRU-13 Gasket/Grille Receiver
Jl Audio Jx500/1d Mono Subwoofer Amplifier - 500 Watts RMS X 1 At 2 Ohms
AudioControl LC2I 2-Channel Line Out Converter and Subwoofer Control
Supercrewsound.com subwoofer box for JLTW5V2-2
Dash:
Jl Audio C2-350x 3.5-Inch 2 Way Speakers (for dash)
Doors:
Focal PS165 High Performance 6.5" 2-Way Component Speaker System
Misc:
Stinger SK4641 4 Gauge 4000 Series Car Audio Amplifier Installation Kit
2 of Dynamat 10455 18" x 32" x 0.067" Thick Self-Adhesive Sound Deadener with Xtreme Bulk Pack, (Set of 9)
Install Bay Back Strap Metal 9 Inch 10 Pack - BS9 - 10
speaker cable
short power cables for lc2i
MDF amp rack
felt covering for amp rack
3M spray adhesive for amp rack
Tweeter comparison:
Sub Comparison:
Sub level control:
Shopping list:
Subwoofer:
Dash:
Doors:
Misc:
speaker cable
MDF amp rack
Enjoy your new Super Duty!
Thanks! I think so. I say that because it's hard to compare before and after. I rarely drive without music. I did a drive the other evening on the freeway and most of the noise I was hearing seemed to be coming from the wind noise on the roof and the engine. I think I would need to treat the doors some more and also treat the front floor and firewall for the most noise reduction. My goal was more about improving speaker performance than reducing road noise as I didn't find the F 250 to be particularly noise to begin with.
Dynamat isn't really a sound deadener. It is used to dampen vibrations which reduces the noise caused by them. If you want sound deadening you need to use something like Dynapad. I did my whole 2008 F150 with just Dynamat & it really wasn't much quieter. I put a sound deadening material on just the back of the cab & the truck was quieter. I planned to do the floors & firewall but never got around to it.
Brock Samson
02-22-2020 07:50 PM
stefanwlsn
24
03-18-2010 11:36 AM
