1992 speed density
1992 speed density
I wan't to get rid of it. I can get one of two motors for a little of nothing. its choice A.)351W carbed in ok shape 180K miles or B.)351W MAF 200K miles. Right now i have a speed density motor and want to change to something I can upgrade easier. The only question is what would be cheaper/easier? Installing the carbed motor and switching over the fuel system/guages. Or going to the MAF (I'd get the computer with it). I've heard that switching the computers is a can of worms where as converting to carb isn't that difficult or expensive besides the need for a trans controler.
I can get either motor for close to free, its just what would be the quickest way to get the truck running again. It IS my DD and WILL be getting upgrades (cam/heads/exhaust/pistons if needed/bearings) I don't want massive horsepower but id like to make 350-450 at the wheel. I'm not a stranger to rebuilding motors (machining will be done by a machine shop) but I've never done anything like this before.
What Brad is trying to say, is that there is no difference between a MAF 351 and a Speed-Density 351. They're the same. The difference is the addition of a MAF + Intake y-pipe, the electrical harness that supports that addition and the computer. It's completely and utterly unnecessary to pull the donor engine. Just grab the MAF intake tube + y-pipe, the MAF sensor, the air box, the complete underhood harness (should just unplug) and the computer.
Also you're going to need to re-think your power goals. 450 RWHP is the exact opposite of "I don't want massive power". That's close to 550 HP if not more at the crank, which is asking a lot out of a 351 without forced induction.
I can also tell you right now that your E4OD will not appreciate that kind of power without supporting modifications.
JRS2
05-11-2015 07:02 PM
wreckless93
06-09-2011 04:33 PM
Gregallen
02-07-2011 07:38 AM
