2010 F150 V8 4.6L. Feels like driving over rumble strips
My 2010 F150 randomly feels like I'm driving over the rumble strips as well as a small jerk like there is a cylinder misfire. If keep it at constant speed it still happens, but under cruise control it stops. Even when load increases like going up a hill.
Welcome to FTE!
Your description sound similar to when transmission fluid begins to break down and the transmission begins to slip a bit. But, it's likely more of an electronic issue.
Is your truck the 4.6L 2V with the four speed transmission or the 4.6L3V with the six speed? Both were offered in 2009/10. 4x4 or 4x2?
How many miles? Are you the original owner?
More info will get yo more replies.
If a bottle of shudder fix made the problem go away, then your best bet is a fluid exchange.
If it were mine, I'd do a fluid exchange with a synthetic transmission fluid and hope for the best.
my 95 t-bird had the infamous torque converter shudder. two different shops told me that it needed a new torque converter, and while I was there I should just go ahead and rebuild it.
a fluid exchange with mobil 1 synthetic ATF fixed the problem and it has not returned since.
if I were to do it again today I'd probably use amsoil OE fluid, since you can get a better deal buying it by the gallon.
if the problem returns after the fluid exchange, you can always put something in it again, but I think new fluid will be the best fix. if I were going to add something to the fluid, which I would only do as a last resort, I'd look at the lube-guard product line.
there are those that say changing the fluid might kill your transmission. I'd counter that with *not* changing your fluid *will* kill your transmission. Not maintaining the fluid condition is what causing your problem ... how is leaving that same fluid in the system better than getting new fluid in there.
don't use chemical cleaners. just exchange the fluid.
keep us posted with what ever you end up doing.
that's the other side of the coin.
I always answer the unknowns from the "what would I do if it were mine" approach, and I'd do a fluid exchange.
I've been told that doing a flush after 100,000 miles is the worst thing you can do. yet every vehicle I've had was flushed around that mileage and I've never had anything but good results.
IMO, new fluid is the only hope you have of saving the trans. it may already be too late, but I'd take the gamble on new fluid.
replace the word "transmission" with "engine" and see if your opinion changes. Would you refuse to change the engine oil at 40,000 miles just because it had never been changed? Or, would you change it and hope for the best?
I just can't understand how leaving old, worn out, saturated oil in any mechanical device does more good than harm.... it just doesn't make any sense. if the fluid is used up then it needs new fluid.
just an opinion. not a baseless opinion, but an opinion, nonetheless.
*UPDATE
Just got back from the trans shop. It was the bridge seal between the valve body and the pump. Failure of the seal is common on the 6R60 transmission. Causes low transmission fluid pressure and gear slippage. I got all new synthetic trans fluid and a new filter with it. Drives like a completely different truck.
Check into the bridge seal. As was mentioned above, a fluid exchange is your best course of action if the problem was solved by a $6 additive. When they replaced my seal I got new fluid and filter anyway, but it sounds like we have the exact same transmission and mine has a few more miles on it, so stands to reason it could be the same problem.
*UPDATE
