Instrument Cluster and Dash Issues - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-16-2016, 08:07 PM
Marcel61 Marcel61 is offline
Marcel61 is starting off with a positive reputation.
I have a 2006 F-350 DRW, 6.0L with 113k miles that I am having an issue with the instrument cluster. The entire dash will lose power (tach, speedometer, all gauges, radio and probably some other stuff I don’t realize). This doesn’t seem to happen when the engine is cold, but once warmed up it seems that when the engine reaches 2700ish rpm first the battery light comes on, them the dash dies. Allow the rpm to come down a little and everything comes back on. It doesn’t affect the engine, headlights, marker lights, cruise control, ect. Everything other than the dash seems to operate fine.
The first time it happened I was pulling a camper and had just come off a stop and was pulling hard up a hill. I thought that it could be a ground problem with the engine under torque, but I checked all the ground straps I could find and all are in tack and in good condition. I have made it do it multiple times and every time it happens at about the same rpm. I’m not sure if there is a link here, but…
Anyone have any ideas what could be causing this?
Do I have one problem, or two? Instrument Cluster and 4x4 Eccles 1999 to 2016 Super Duty 2 02-19-2016 11:50 AM
My “How To” install a F-150 Cluster w/Tach into an Aero 93nighthawk Aerostar 39 09-23-2015 08:55 PM
Dash/gauges problems NativeDescent 1987 - 1996 F150 & Larger F-Series Trucks 10 07-13-2015 03:12 PM
Instrument Cluster and Radio cutting out njf350 Electrical Systems/Wiring 5 03-17-2015 06:57 AM
Standard instrument cluster issues... chuggins143 1987 - 1996 F150 & Larger F-Series Trucks 22 01-11-2015 07:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
