1996 f150 4.9 tach install
It will go onto the ground side of the coil. The colors Ford used changed over the years, so I'm not particular sure what your color is. Easiest way would be to unplug the coil, turn the key on, and check which pin doesn't have 12 volts on it. That's the wire you need to hook into.
Also, you do know the truck is pre-wired for a tach cluster, and you can just take the instrument cluster out, and put the tach module from a tach cluster in, and it will work?
Sorry to disagree, but have read several posts that have had problems trying to use wiring in the instrument cluster. I had the same problem with my 87 4.9 trying that. Much easier using coil wire. IMHO
I'm not saying to use the instrument cluster wiring for his tach, I'm saying an aftermarket tach is not necessary for a '96 truck. He can go to a junkyard, find a dashboard with a tach in it, pull the tach and fuel gauge module out and put them into his cluster and it will work.
jmkelly
06-09-2007 07:56 AM
bmhandyman
10-08-2004 02:57 PM
gordon24
05-08-2003 08:16 AM
